Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,2 GHz (Turbo Boost jusqu'à 3,4 GHz), 2,5 GHz (Turbo Boost jusqu'à 3,7 GHz), ou 2,8 GHz (Turbo Boost jusqu'à 4,0 GHz) avec 6Mo de cache L3 partagé.
748 questions Voir tout
Battery compatibility. A1494 vs A1618
Hi.
I cant figure out the compatibility of macbook battery in the late 2013 - mid 2015 A1398 models.
Will a battery with model number A1494 fit a 2015 A1398 MBP? Or will i need a newer battery with model number A1618?
Some sites / vendors says the A1494 will fit, some says it does not. I get the difference in the mAh. 8440 mAh in A1494 and 8740 in A1618.
Can anyone clarify?
Thanks a lot!
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
2 Réponses
Solution retenue
If you review the iFixit batteries
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
MacBook Pro 15" Retina (Mid 2015) Battery
You’ll see the power values are different!
While Apple did stick with the same dimensions and the connection to the logic board is the same for both. The chemistry of the batteries is different as such the charging rate programed in micro-controller and SMC what match up properly. I suspect some of the battery failures we have seen are do to the wrong battery being used.
Image MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
Produit
$79.99
Image MacBook Pro 15" Retina (Mid 2015) Battery
Produit
$99.99
Indice 4
9 commentaires:
I see, Thats probably quite relevant.
thanks for the reply Dan!
par
@ajes - Don't forget to score the answer and accept it - Thanks!
par
@danj - From late 2012 when new type of battery was introduced and apple started glueing them in, is calibration not required anymore? And if not why is this when "old" types in 2010 - 2012 did need it.
Better monitor software or different batteries?
Calibration = Charging battery full 100% + 4-5 extra hours, draining bat through normal use and charge again.
I have replaced battery in some A1278 sometimes the replace battery message comes within a year and a calib + SMC reset usually helps.
par
I calibrate the batteries I put in. Apple still does it as far as I know, so I have no idea why you think it's not done.
Calibrating a battery later doesn't really change things. All you are doing is resetting the high and low water points, over time they will drift back to where you had them before you re-did the calibration. Yes, it does appear to improve things but at the risk of overheating your battery.
par
Hi Dan and Anders
Would it be possible to use the A1618 battery (with 99Wh capacity) in a Macbook Pro 15 Retina Mid-2014 that's originally fitted with a 95Wh battery?
par
Voir 4 commentaires en plus
Actually, the power rating is showing up as 99Wh in both of those links. I don't know if it is a recent typo.
Indice 0
Ajouter une réponse
Anders Laursen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 73
Total : 3,644
