Hi @loveparade !
I have bad news for you. I have to had buy new monitor insted of it. But of course paralell I spend months tried to fix it or looking a cable supplier. I wrote cable distrobutors with no aswer. Only one cable I think is not a value for them.
I found the name of the cable, but I could not buy it from anywhere. I do not remember the type. I found a similar that can found now:
https://www.aliexpress.com/item/32809840...
!!! But the original cable serial was slighty differnet not that I linked above: CI1406.................
I googled the screen panel and main board and any other part has got number on it and somewhere found that CI1406..................
Finally I bought that:
https://www.aliexpress.com/item/17982170...
But this cable only fitt in in the panel but not in the screen, so that was just waste of the money.
With no sucess I pressed back the broken cable end and glue it in the socket. It is worked!
But when I pressed back I have just one end borken (check my pictures above) so that can be settled in the correct space, I needed to glue to stay there.
When I tested the connection and worked, I used a heat glue gun, and glue the plastic connection into the socket/ into the screen.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
Hello, I have the same problem, I think that in any electronics store you can buy the connector that usually breaks, could you tell me the pintout of each end of the cable, especially if they are sequential? That is, if they do not have any cross pins from side to side. Thank you.
par Ivan
