Aller au contenu principal
iPhone 4 pouces commercialisé depuis mars 2016 avec une configuration de matériel similaire à l'iPhone 6s. Disponible en Argent, Gris sidéral, Or ou Or Rose, avec 16 ou 64 Gb de stockage. Modèles A1662 et A1723.
20 questions Voir tout
Phone charges only sometimes
Hi, I have this iPhone SE that charges every time when it’s turned off, but then it does charge only sometimes.
For example - phone is turned off, I plug the charger and it charges until 100%. When I remove the cable and put i back, it charges. When I flip the cable, it does not charge. Then I plug it again (the same way) and it starts charging again.
When I turn the phone on without charger it does not charge at all.
I have tried other battery and system connector, but it is the same. Then Tigris and Tristar chips were replaced, but still the same.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
First check to make sure there is no lint or dirt stuck in the charge port which is blocking the connection (you’d be surprised how often this happens), then try another cable, its possible the one you have has a burnt out pin or poor connection. If neither of those solve the problem then I would recommend replacing the charge port.
Hope this helps!
Indice 0
1 commentaire:
I have tried other system connector, but thanks.
par
Ajouter une réponse
Adam Grufík sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 91
