Why EWA A106 is not charging or turning on?
One day my device does not turn on or charge. When I tried to charge it, the red light which shows that it is charging will lit up but after a few minutes it would stop. When I try to press and hold the power button it will not respond or will lit up.
Most of the solution online suggest to restart it by pressing power button and volume button but the problem is this one does not have a volume button. Only single power button. I know it is china made but I would like to try my luck if anyone has encountered the same problem that had a solution or just ways to avoid it before I buy a new one.
Thank you for your help!
5 commentaires
Hello, could you tell me if you solved it and how did you do it, I have the same problem :/, surely it is due to the battery since I always used it to the maximum of the device
par Isaac Villarreal
Originally the charge lasted 60 minutes or more, now it lasts about 10 minutes
par cakecop
Hi @aquinas
Try replacing the battery (see below for possible solution for how to do this).
Even rechargeable batteries have a life span
par jayeff
My EWA A106 stopped taking a charge after about 3 months. I took it apart. A waste of time.
The mfg process glues everything together. I popped the top plate off using a paper clip to lift it, then stuck a razor blade under it and worked it around until the plate came off.
Then you see a lot of glue. Remove some. There is a thin black plastic ring glued in that holds the top speaker in. Get the ring off, then dig out the rest of the glue and the top speaker was able to come out.
You can now get to the battery, but the entire circuit board is covered with a pile of glue at the terminal. I decided not to try to scrape the glue off to try to remove it. I tested the battery terminal. It measured 3.25v (on the 3.7volt battery). Plugging it in gave me no more voltage.
Bottom line, the power converter/charger circuitry inside is what quits, not the battery. This is only after less than 4 months of use. The battery is dated 2020.09.12, so it isn't very old.
Sounded nice, but it quickly became trash.
par Brad Slaughter
Hi
Guys how can i make ewa a104 direct wiring charge because i have no longer have battery
par yyox 4
