Hi @hecermer,
What is the model number of the microwave oven?
If you are only adjusting the cooking time duration and the power setting and not actually starting the microwave oven, then it appears to be a problem with the control board or the wiring connected to the control board e.g. relays operating to switch the appropriate connections to regulate the amount of power required by the magnetron circuit. etc
If you mean that you set the time and turn on the microwave oven then it could be a number of things. The magnetron, the turntable motor, the fan etc
The door interlock switches only switch the power to the oven’s other components for them to operate and sometimes if the interlocks are faulty allow them to operate when they shouldn’t so it may be them but then you would suspect that the breaker might trip when the door is first shut
In either event the oven would have to be opened and further tested to determine what the problem actually is.
Be safety aware when working in a microwave oven. The HV capacitor can store >6000V DC for months, even if the oven hasn’t been connected to the power for that length of time. This voltage can seriously injure you if you don’t know what you’re doing. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the oven’s cover has been removed and before commencing any other work inside the oven.
If you don’t know what you’re doing, call a reputable, professional appliance repair service and ask for a quote
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
Just a thought .... how many other appliances and/or lights ("loads") are connected to the same circuit breaker? In other words, what else stops functioning when the circuit breaker trips? It could just be the fact that you are drawing more than the maximum of 15 amps that the breaker is rated for.
par Klaus Martinek
