Is it possible to connect MacBook Pro A1990 LCD in A1707?
Hello,
I have a MacBook Pro A1707 with a crack on the glass. I can buy cheap screen assembly from A1990. Would it be possible to connect it and if not, then why? Both screen have the same specs. Alternatively, do you know if it is possible to separate the protective glass from the display?
Thank you for your response
1 commentaire
well, i would disagree, it is possible. but it is not entirely compatible. the. The camera would not work and you need an external monitor to be connected for the first time when it is booted. once after that you can put it in sleep mode. and start using it as usual.
So it is possible to replace A1990 with A1707. i have done that and it is working just fine.
par Albin
