Replaced the two cables, now the screen looks like this
Replaced the two cables, now the screen looks like this, not sure if I damaged something while I was trying to replace the cables.
I had noticed the orange strip connected to the LCD was a bit damaged, would that be the reason? Everything else works fine, but the screen won’t show the apple and the OS
Update (10/22/2020)
I have fully replaced the LCD and now it shows up like this:
https://imgur.com/gallery/WzCjjNR
Is there something wrong with the cable hinge?
Update (10/22/2020)
Update (10/22/2020)
https://imgur.com/gallery/GSp5sdx here are the pictures i’ve taken, hopefully this is helpful
4 commentaires
Can you take some pics of the LVDS logic board connector as well as the cable end so we can see if they are damages as well.
par Dan
Not good ;-{
The LVDS cable and connector look fine! So you either got a bad/wrong LCD panel if you replaced it alone or your systems logic board has issues as well. I would double check things with an external display to help focus what you need to work on.
par Dan
did you buy the cables for the same modles?
par ramon burf
yes, they were purchased separately, and didn't come with the LCD screen
par Michelle L
