Aller au contenu principal
Pour réparer ensemble - Je crée un compte
A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
Water damaged double socket
I had water leaking into my garage and water has gone inside the socket unit, which was tripping my lights in the house, I shut down the fuse box and the lights in the house came back on, having investigated it I found the socket to be wet damp and I'm drying it out, will the unit work when dried out or will it need replaced. Thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
It depends on how wet it got and also what the socket’s electrical connections material is made of as the impurities in the water can create corrosion which may be a problem later on, especially if it is humid where you are.
Check that the electrical cable is also completely dry. I don’t know about electrical cables but have seen the results of water traveling up by capillary action under the insulation covering telephone cables and causing problems so I imagine that electrical cables would be no different.
Usually sockets aren't that expensive to replace so it may be better to replace it if in any doubt. Just my opinion on this
Indice 1
Ajouter une réponse
guyarbuckle sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 427
