My pc won't turn on when the power cable is connected to the primary h
Hello guys, can I use an external hard disk as my primary hard disk on my PC because my pc won't turn on when the power cable is connected to the primary hard drive. Thanks in advance for your advice.
Hi @cipherstack ,
What is the make and model number of the PC or motherboard if a custom make?
par jayeff
Manufactured by LG:Alpha-Sp;
Can't find the model number.
par Shedrack
@cipherstack
So there is no product label on the underside of the laptop with model info on it?
par jayeff
It's actually a desktop.
par Shedrack
@cipherstack
What is the motherboard's board number? Should be printed in the motherboard itself.
Since it appears to start without the HDD connected, (is this correct?) can you try another power connector e.g. has the PC got a ODD installed, that you can use the power connection from at all to connect another HDD that maybe hasn't been damaged.
It mightn't boot all that well if the OS on the replacement HDD was installed on another motherboard since the OS is matched to the system hardware. You may have to reinstall the OS onto the new HDD from a USB recovery disc.
If you have a DMM (digital multimeter) you can also use the paperclip testto also make sure that the PSU voltages are correct as well.
par jayeff
