Cannot remove screen from Apple Watch, quite stuck on!
I am trying to remove the screen of my Apple Watch series 2 and have put so much time and effort into trying to remove the screen and it simply will not lift off. I used the iOpener to warm it (up to 10 minutes!), an Xacto knife to get under the screen, a razor blade to get under there—I cannot get that screen lifted. Anyone else have this issue and what did you do?
6 commentaires
Did someone else work on your watch?
I had one where the person who fixed it used Crazy glue thinking that would prevent the crystal from falling off. Yep! It did that! And stopped the force touch from working too.
I too couldn't open it up either to fix the first persons fix!
par DanJ
No, the watch is original and never opened. It functioning just fine,
I just am looking to replace the battery.
par William Ciaccia
You could try an air powered suction cup that can grab a good portion of the crystal. A good vacuum pump will be needed and use a bit of solvent to help soften the force touch gasket adhesive.
par DanJ
Solvent such as rubbing alcohol?
par William Ciaccia
Apologies, I meant isopropyl alcohol in my mind vs rubbing alcohol. I'll try it in conjunction with heat.
par William Ciaccia
Afficher 1 commentaire en plus
