Aller au contenu principal
The HP Laserjet Pro 200 Color MFP can be identified by its model number: CF145A. This wireless-enabled color multi-function printer provides ePrint, touchscreen access to apps, and versatile scan, fax, and copy options.
Power Button Assembly - Where to get it?
My printer is experiencing the power button issues:
Remplacement du bouton d'alimentation du HP Laserjet Pro 200 Color MFP
The button itself is electrically fine, but one of the MOSFETs seems to be the issue. Out of laziness I’d just like to replace the entire assembly. Does anyone know where to buy a replacement?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi @badlarry ,
What assembly do you mean?
Looking at the image (click on image to enlarge) in the guide for the power button board, there appears to be only the button and a LED on the board unless other components are on the other side of the board of course.
The board number for the power button board is RM1-8711. The supplier in the link is shown only to give an idea of the cost. There are others that may suit you better. Just search for RM1-8711 to get results.
If you mean the assembly where the power button board connects to, find the board number and then search online using the board number only to hopefully find suppliers.
Here’s a link to the parts catalogue for the printer. It may help a bit as it shows all the parts but unfortunately not all the part numbers, only selected ones.
Indice 2
1 commentaire:
Hi @jayeff the board is more complex than that. There are 3 transistors on the back of the board. My guess is a latching circuit. Thanks for the link to the replacement assembly!
par
Ajouter une réponse
Matt Wood sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 172
