Scratched back of logic board while fitting back glass
Hi,
I was scraping off back glass on iphone and scraping tool slid under wireless charger pad and caused a scratch to appear on the back of logic board. The phone no longer turns on could this be the cause or could it be a damaged power flex cable that I also may have scratched, I don’t think it is the latter as if it was the power flex cable the phone should switch on when plugged into a charger?
Update (10/30/2020)
attached
Update (10/28/2020)
Uploaded sticker removed
What did you use to heat the glue. Hot air or laser.
par daniel
I used Hot air
par Wayne
Is it possible to fix back of logic board or will i need to buy a new one
par Wayne
@albert123456s let us see what and how damaged this all is. Post some GOOD pictures of all of this with your QUESTION.
Ajout d'images à une question existante
par oldturkey03
@albert123456s maybe to much heat as the 8 would require more heat than an iPhone X to remove the rear glass. Take out the logic board and as old turkey suggests add photos.
par daniel
Voir 5 commentaires en plus
