880m GTX startup routine
Good afternoon iFixt community,
I have a question about the startup sequence of the iMac.
First let me explain what happened.
- I have a iMac with a ATI Radeon 4850 512MB MXM card, which works perfectly fine.
- I harvested a 880M from a laptop and flashed this with a BIOS version that support Apple.
- I replaced the card and got external display using mini DP.
- It can run games and the 880M is recongized and works.
But Internal display is not working with this new card. I put the ATI 4850 back and the internal works again. so the cable and display is fine. PSU is fine too.
Does somebody knows whats the diffrence between the ATI 4850 and 880M with startup, could it be that the 880M is not sending the right signals?
I measured the voltage on the 14 pin PSU connector all seems fine. Except pin 13 for enable backlight always is 0.00v to 1v.
If I solder a wire from a 3.3v source to the pin 13 will it work?
I think maybe the 880M doesn’t send a signal for enable backlight and startup video using the LVDS connector I have no clue or if the display and video card together draw to much current together? But external works, but external is of course is different power source for its display.
Does someone have a clue??
My last resort is soldering wires to generate/ force signals. But I have read in other iMac’s that people did this and killed the logic board because sometimes signals only need to be a second there.
Update:
Dan fixed my issue.
For anyone else who see this or want the info .. in the link Dan posted
They said it doesn't work in high sierra
But here it does, also I didn't lose boot screen it's there using a vbios from nickey on macrumors I found it a while back.
Catalina and others didnt try.
1 commentaire
Your system came with either a AMD Radeon HD 6770M or Radeon HD 6970M. And offered 512 MB GDDR5 (Radeon HD 6770M) 1 or 2 GB GDDR5 (Radeon HD 6970M) of Video RAM.
par Dan
