Aller au contenu principal
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
20 questions Voir tout
Torx T6 and T8 screwdrivers to change internal hard disk.
I have a query, I want to change my internal hard drive from my Mac Mini (mid) 2011, and my query is whether to remove the fan screws and other parts, which from what I was informed is the Torx T6 screwdriver.
My question is: to remove it I need a Torx T6 screwdriver with a hollow point or the Torx T6 with a flat tip will work for me. From what I have read, that the hollow point Torx are called Precision Torx or are identified with an "H" after the number in this case: "T6H". The same query is to remove the cover where the WiFi is, should I use a Torx T8 hollow point or does the flat point work for me? From now on I thank you get me out of this doubt, before doing something wrong. Thank you very much and greetings.
Image (Augusto)
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Here’s the guide to replace the HDD Remplacement du disque dur dans le Mac mini mi-2011
You only need the standard Torx driver T6 & T8
To clarify about the different Torx I only know of two types:
Standard
Security
The security version will also work on standard fastener!
Indice 0
Ajouter une réponse
Augusto sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 531
