Aller au contenu principal
La GameCube est le quatrième système de jeu sur console de Nintendo. Cette réparation console est simple et ne nécessite que des outils courants.
20 questions Voir tout
Why is there no video?
So my GameCube has no video, but it has sound. Further inspection shows that only the red input is working and not the white and yellow.
i tried switching cables and that didn’t work.
thanks in advanced
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Hi,
Have you proved that the the AV input (yellow - video + red & white - left and right audio) on the device (is it a TV?) that the game cube is connected to is working OK, you didn't say? You only said that you changed cables.
Try connecting another device that has an AV output to the device, e.g. a dvd player and check that there is video and audio when using it to determine whether the problem is in the game cube or not.
par
Hi! So I tested the same cables and TV with another GameCube I have, and it works fine.
Thanks!
par
Ajouter un commentaire
2 Réponses
Solution retenue
Hi,
Here’s a video that may be of some help with locating the problem.
Also here’s the ifixit Nintendo GameCube guides as well which may help with getting access to the component parts
Indice 1
How about check to see if the video connector has a bended pins or damaged pins?
Indice 0
1 commentaire:
There at no bent or damaged pins
par
Ajouter une réponse
David Lank sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 27
30 derniers jours : 113
Total : 8,747
