Aller au contenu principal
Seconde génération du Fairphone, conçu par l'entreprise sociale du même nom. Sorti en décembre 2015. Numéro de modèle : FP2-XCVR
74 questions Voir tout
I need to put my speaker on when calling
I have a Fairphone 2. it still works quite okay, I only have the issue that the one receiving my phone call doesn’t hear my voice unless I put the speaker on which means that I don’t have any privacy anymore as everything we talk about is loud and clear for everybody :(. What do I have to replace in order to solve that problem?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
First use a strong light and a magnifying glass and check if you can see if the voice inlet hole on the bottom edge of the phone appears to be blocked at all. If it is or if you’re not quite sure, do not use a pin or probe to try and clear it as you may damage components in the phone. Try using a vacuum cleaner to suck out any obstruction.
If you still cannot be heard on a call, most probably there is a problem with the primary microphone
Here is a link to the ifixit Remplacement du microphone du Fairphone 2 guide that will help.
There is also an app available on the phone that allows you to test the primary microphone as well as a lot of the other hardware in the phone which may also help.
Indice 1
Ajouter une réponse
Rina Teeuwen-van der Ende sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 184
