does washer have filter
mdl#cw4571379
does the washer have a filter
mdl#cw4571379
Usually washers have two filters. One filter is for your water pump and the other is for your built-in lint filter. Washers nowadays usually just have one accessible one and that is the water pump filter. The lint filter like I said is usually built-in on all the newer washers and therefore it is hard to access and clean. But if you can it will greatly increase the life of your washer. Usually the lint filter is located below the tumbler on the front end loading washer. And behind the washer if it is a top loading or on the side. If you can clarify the make and model number of the washer. It would be a quick fix and help. Any problems?
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 28
Total : 2,875
Hi @laduckster ,
Please verify the model number as the number that you posted shows no results?
par jayeff
