Aller au contenu principal
Modèle A1502 / processeur dual-core Intel Core i7 2,6 GHz (Turbo Boost jusqu'à 3,1 GHz) ou 2,8 GHz (Turbo Boost jusqu'à 3,3 GHz) avec 4 Mo de cache L3 partagé.
MacBook Pro 13" 2014 A1502 Screen On and Off
Hello,
My MBP starting normally, but after few seconds the screen turns to black and back to normal over and over. Fan is still spinning. Just screen is dimming or on/off.
Sometimes, while screen turns to black mode, touch pad is stoppage or acting slowly and keyboad backlight led is not working. It also on/off depending on screen status.
What shall I do check the first?
Thank you for your any advice!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
I fear your logic board is liquid damaged!
Let’s check it out, follow this guide Remplacement de l'écran complet du MacBook Pro 13" Retina mi-2014 follow the fist steps to disconnect the battery stopping at after Step 6. Now jump down to Step 11 disconnecting the internal display cable. Now you need to inspect both the cables contacts as well as the the sockets solder joints for any corrosion, staining or damage.
Post a couple of sharp images if you are not sure Ajout d'images à une question existante
Image iFixit
Tutoriel
Difficulté :
Très facile
2 - 5 minutes
Image MacBook Pro 13" Retina Display Mid 2014 Écran complet
Tutoriel
Difficulté :
Modérée
1 hour
Indice 0
Ajouter une réponse
HG Jung sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 154
