Battery problem - battery not charging - power source AC adapter
Hi all, thanks in advance for the help.
Since when did it occur: After I unscrewed my Macbook and put new thermal paste on the heat sink I am getting this problem.
Problem: As the title says. My battery doesn’t charge altough the Macbook detects the battery. It is using the power adapter to work. If I unplug is the Macbook powers down.
See bottom of the message for battery information (it is in Dutch)
Is it possible during the re-assembly of the logic board I forgot to re-connect something? Don’t know what else could be causing the problem.
Edit: the Macbook has been plugged it the past few hours, it was turned off, the battery stayed at 89%.
Sorry I don't speak dutch ;-{ And translating the image would be harder that if we got a dedicated app like CoconutBattery for the details.
Please, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante
par Dan
I am currenty on the road but will post it later. The app is already installed and I didn’t see any special things. Battery is located, gets power but doesnt charge.
par Pieter
If your system battery needs charging ~80% charged plug in the MagSafe give it a minute and take the snapshot then so we see the charge rate.
par Dan
@danj I have edited my guestion with a photo of Coconut. Anything you can make out of it?
I don't really know what you mean with the second response about the system battery. But the Macbook has been plugged in for a few hours and the battery stays at 89%.
par Pieter
