CL error code L G front load dryer
CL code stays on. Stands for child lock but my model does not have a button on the panel
Hi @coachvic,
What is the model number of the dryer?
If it is a DLEX3570V or DLEX3570W then press and hold the Easy Iron button for 3 seconds to either lock or unlock the controls.
If it is a WM3670HRA then press and hold the Pre Wash child lock button for 3 seconds
Hi @shawn03 ,
Activating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. The Control Lock icon will be shown in the display and all controls will be disabled except the Power button.
Deactivating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. Once set, Control Lock remains active until it is manually deactivated. Control Lock must be turned off to run another cycle.
Clean Filter Reminder:
The display will show Clean Filter when the dryer is turned on as a reminder to clean the filter. It turns off
when the Start/Pause button is pressed..
Thank you for your two suggestions on how to turn off the CL feature on my
LG dryer. I was just about ready to pull out, what little hair that I have left.
Dernières 24 heures : 7
7 derniers jours : 19
30 derniers jours : 114
Total : 11,566
2 commentaires
My model number is dlex3700v
par Shawna
The clean filter light is on but the code cl is showing
par Shawna
