Doesn't have a SSD and I don't have another Mac to download OS-X
I tried to make a bootable USB but then I saw that it doesn’t have a USB 3 port so I tried a USB 2 and still didn’t see it, should I get a new hard drive for $30 or is there a different way.
I have tried to use the commands control R but nothing also seemed to happen.
I don’t have another Mac so is there a way to download the OS-X from a Windows PC?
5 commentaires
Can you give us your exact model as Apple has quite a few versions. Plug your systems S/N here EveryMac - Lookup Let us know what you find.
par Dan
the sticker on the back is torn off but on the battery it says its module is A1322 I don't know if that will help.
par UKRGaming
Well that's the battery part number not the system ;-{
So that tells us you have a 1MacBook Pro 13" Unibody A1278 Mid 2009 to Mid 2012 Here's the P/N for reference MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery
That still covers quite a few models ;-{
As you can see they all look very similar MacBook Pro 13" Unibody Look through these can you point yours out?
par Dan
@danj I'm pretty sure that it is the Mid 2009 Model A1278 I also bought a SATA cable for it and it says that model but I wasn't sure is it was for that model only. Is there a way to download and run mac OS X on a mac from a windows PC?
par UKRGaming
Here's the specs for your system: 13" MacBook Pro 12.53 GHz Core 2 Duo (SD/FW)
par Dan
