Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
Pages, Numbers and Keynotes on macOS High Sierra
I have been told not to go above high sierra for this machine but i need pages, numbers and keynote.
are there any workarounds or do i need to upgrade my OS to macOS Catalina.
I know that it can be done via iCloud but i would need it to work offline also.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
This gets complicated!
First Apple has moved on with newer versions of the apps so you might encounter an issue trying to get them from the Apple online App Store (not iCloud). So first try logging into the Apps Store using the Apps app on your system. Are you able to down load them from there at all? Or do you get a warning you need a newer macOS.
Even still you should be able to get the older version of the apps for your macOS you are using. Most people have a backup of their stuff to restore to their system do you still have it? That would be the easiest way, restoring it to your new system. If that’s not possible, see if you can find a friend with a Mac that is using an older version of the apps having them make a backup of their apps using Time Machine so you can restore them onto your system (apps only not the user accounts) even if they are older you should be able to upgrade to a more workable version for your macOS version from the App Store.
You might find an independent servicer locally who has copies of the older versions to help his customers. I would give that a try, they may ask for a fee for the service.
The last way is buying a copy of the older versions from an online seller (the very last option)
iCloud ??
There is no requirement to use iCloud here in any way. Apple runs all of their apps On System and mostly free, they have never required active connections to their servers to run any of their apps. Now with that said, you might have a shared library of elements in a work place on a server (yours) or for safety use iCloud to store your created files so if your system where to fail you have a backup or want to share them directly.
What you are thinking of is Microsoft’s approach with Office 365 which offers an Online free version or paid subscription version, or a On System version at a higher cost.
Indice 1
2 commentaires:
Thank you Dan
I dont have a back up or older version as i have just set this up from scratch.
should i just upgrade to catalina? would that not solve the problem? or would that create more making the system too slow?
par
@macps - There is no good answer here sadly. With only 4 GB or memory you will run into wear issues with the SSD. For reference look at this M1 Mac users report alarming hard drive health readings While you have an Intel chip in your system the same issue happens with it. The less RAM your system has the more it depends on the drive to run Virtual RAM to extend the RAM footprint. So the larger the OS RAM footprint and number of apps (and their footprint) will have a big bearing here.
So while the easy way would be to just jump to macOS Catania overtime your SSD will wear-out sooner!
So what is your use here? Is this a stopgap until you've collected enough pennies to buy something more powerful?
par
Ajouter une réponse
Pete Singh sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 20
30 derniers jours : 55
Total : 3,921
