Too Slow and Doesn't Wake Up
It’s been a couple of years and I’m not a techie so bear with me. My battery was dying so I replaced the battery. I also ordered a SSD to replace my HD but I didn’t replace the SATA cables, and I expanded my RAM to 16 GB.
My system specs are:
- processor: 2.3 GHz Intel Core i7
- memory: 16 GB 1600 MHz DDR3
- graphics: Intel HD Graphics 4000 1536 MB
- Trim support = yes
Battery says:
- Charge Information:
- Charge Remaining (mAh): 3836
- Fully Charged: No
- Charging: No
- Full Charge Capacity (mAh): 5252
- Health Information:
- Cycle Count: 81
- Condition: Service Battery
- Battery Installed: Yes
AC Charger Information:
- Connected: No (plugged in)
- Charging: No (battery icon shows it’s charging)
My battery has never said it was fully charged even when it showed 100%. I followed the video tutorials on how to install a battery and condition it and how to install an SSD and boot up with a bootable USB. The videos also showed how screaming fast their “new" mid-2012s were with a timer. I didn’t get to enjoy any of this. I was wondering if I needed to replace the SATA cables.
Also, I had made the mistake of installing the 64-bit OS, then realized nothing worked with it and my Excel spreadsheets were literally backwards. I then erased everything again, re-initialized (again following a tutorial) and loaded Mountain Lion OS and upgraded to Mojave, which is where I’m staying put.
So these are my problems. My Mac is very slow and won’t hold a charge for very long even with the “new" battery. My last battery lasted 9 years. When it’s charged up, I take it off of the charger, use it then close it. When I go back to use it, I have to reboot sometimes several times a day with it plugged in and the battery is at 95%. Sometimes it’s reliable. Right now it’s being a pain. I’m not sure if this is a hardware issue, or if I have legacy files from the 64 bit system when I restored my files and need the “genius” bar. I did see another question regarding the same battery issues I’m having and the responder suggested the coconut battery app. I can’t get it to download and half the time I can’t get access to the App store.
Update (03/01/2021)
@bmx2019 I believe the fan is running because my laptop is always in my lap and it doesn’t get overly hot.
@dan I tried holding down the D at restart and received an error message about a missing file. I also tried option D at restart and recieved the same error message ‘Cannot load EFI/Drivers/Test/Support.efi. I read through Apple Support looking to see if the .diagnostics folder was in the right place but wasn’t able to find it.
EDIT: According to the Apple Forums it appears the Boot ROM was changed when upgrading to Mojave and option D is no longer available. Downgrading does not change the firmware.
@gizmowizards I did adjust the SMC following online instructions. I've been poking at this problem for over a year now. I haven't adjusted the energy saver settings. On battery and power adapter they’re set at 15 minutes.
Update (03/02/2021)
I can’t seem to upload my screenshots using the media manager. I add my screenshots, press “Upload Media” it takes me to a new screen. The new screen has a “Back” button and an area to upload media or a URL. When I drag and drop my screenshots into that screen it takes me back to my original screen and the circle continues. What am I doing wrong?
Update (03/02/2021)
@danj The only way I could load the images was to use a PC (smh). The battery was purchased 7/19, probably installed 8/19:
8 commentaires
Is the fan spinning? Look at MacBook Pro 15" Unibody Mid 2012 disassembly page. Check all fan connections? A non-working fan will slow down mac.
par bmx2019
Lets run the onboard diagnostics to see what it tells us. Restart your system and press the D key.let us know what the errors are.
Reference: Mac startup key combinations.
Let’s get a better view of things with your battery and charger, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Ajout d'images à une question existante. Make sure the MagSafe charger is plugged in.
par Dan
@dan I can't get coconut battery to download from the app store. I've tried to download both Battery Health and Battery Health 2 with no success.
par paintslinger88
@paintslinger88 - Its not in the Apple App Store! Click on the Blue URL link I posted in my comment above.
par Dan
I would start by checking the CPU temp you may need to replace thermal paste, and also rather than installing Mountain Lion and upgrading I would install straight to MacOS Catalina. Will save time and is always better to start with a sound foundation.
par Randy Northrup
Voir 3 commentaires en plus
