Female Jack Port faulty (?) what to do next
When rotating the headphone cables, audio disconnects. But only with SOME cables.
I have a bunch of cable that I tested, and it seems like the sturdier the plug (newer), the better the connection is (it doesn’t disconnect when rotating, some are just fine !)
But, no matter the cable, a little pull, and it disconnects.
I tried to apply alcohol (gently) to remove any tarnishing (?) but didn’t work.
Could it be a weak pin on the female port ?
As far as I know, I can take it apart, disassemble it, solder a new one (I highly doubt i can)
Buy a cheap USB audio adapter (last resort)
Buy a new IO Board.
Is there anything I can do to “bend back” a pin ? Am I missing something and the problem is somewhere else ?
Thanks in advance
