Panasonic TC-P50U50 T-2 TV keeps tunring off and on.
TV turns off and on, displays message “An error has been detected an repaired” (or something like that). I have and OTA antenna plugged into the coax port and a fire stick in the HDMI port.
Indice
0
Hi,
What happens if you remove the Firestick?
par jayeff
I've tried disconnecting all inputs, removing batteries from the remotes (including blocking the IR receiver on the TV), unplugging and resetting the TV to no effect.
par Scott Peirce
@Scott Peirce
Is the red standby power LED blinking when the TV shuts off?
If so count the number of times that it blinks as this will help, as it is an error code.
If the Tv just switches off and the standby power light just goes to red (indicating TV is in standby) then the TV turns on again I'm wondering if it is a firmware problem as most hardware problems are detected and an error code is shown when the TV is shutdown.
par jayeff
