Aller au contenu principal
iPhone 4 pouces commercialisé depuis mars 2016 avec une configuration de matériel similaire à l'iPhone 6s. Disponible en Argent, Gris sidéral, Or ou Or Rose, avec 16 ou 64 Gb de stockage. Modèles A1662 et A1723.
1051 questions Voir tout
iPhone SE: battery charging only 13% and restarting
Hello,
I dropped my iphone SE (first generation) from a considerable height. It was in a silicone case that popped out after the hit. As a result my screen was damaged beyond repair. I ordered a new one and replace it, but then I noticed that the battery only charges to 3-4%, so it was constantly charging. I thought the reason was the battery, so I bought a new one. After the replacement the problem remained, the battery is charged only to 13% and the phone restarts shortly after opening apps. Powered off the phone and cleaned the plug with rubbing alcohol, nothing changed.
My question is: could this be due to the charging port or is it probably some other hardware problem? If not the charging port, what could be the reason?
I love my phone very much because it is small and I am attached to it. I want to know if there is any chance to save it or it is not worth it :(.
Thank you in advance :)
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Best course of action is to replace the charge port and the battery, due to the charge port most likely being the cause. The battery is just to be sure. The links are included at the end of my answer, as well as the guides. Happy Fixing! TAG2YT | iPhone SE (1st Gen) Battery iPhone SE (1st Gen) Lightning Connector and Headphone Jack | And here are the guides: Remplacement de la batterie de l'iPhone SE Remplacement du connecteur Lightning de l'iPhone SE
Image iPhone SE (1st Gen) Lightning Connector and Headphone Jack
Produit
$19.99
Image iPhone SE (1st Gen) Battery
Produit
$29.99
Image iPhone SE Batterie
Tutoriel
Difficulté :
Modérée
40 minutes - 1 hour
Image iPhone SE Connecteur Lightning
Tutoriel
Difficulté :
Modérée
Indice 0
3 commentaires:
Than you for the fast reply!
I have changed the battery already, but the problem reminded.
For this reason I was wondering if it is due to the charge port or something more complicated that will be very expencive to fix.
par
Like one of the charging components on the logic board for example.
par
Replacing the charging port would be the best thing, being as it is likely the suspect.
par
Ajouter une réponse
Zeld Ina sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 56
