Better late then never I guess, and for all future references.
The issue is most likely one of 2 things. Gunk buildup at the 'filter' causing water to overflow into the collection box. This is easy to fix just by using a toothbrush on the inside of the capsule holder, towards where the coffee comes out.
If that doesn't help it's most likely gunk buildup or defective o-ring. You can get a replacement o-ring, i believe it's 33mm inner and 35mm outer. But a common problem with these machines is just a bit of gunk buildup. The o-ring is also quite loose.
To get to the o-ring unplug the machine, remove the water reservoir, and all other easily removable trays.
If you close the capsule holder halfway you'll see a clip used to hold the actual holder in place. The same clip is on the bottom. Undo both clips, twist the holder and it'll fall out of the bottom. There you can remove and clean the o-ring. No need to disassemble.
I've heard of some using pressurized air to blast it clean as well. But didn't have effect on mine.
Fair warining though, it's a real pita to get there. Took me a little over an hour to unlock both clips.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
