Hi @dampri ,
Did you mean RF220NCTASR/AA as I cannot find anything on the model number you posted?
It seems as though there may be a problem with the evaporator fan in the freezer compartment.
This fan is used to circulate air across the freezing cold evaporator unit and blow it into the freezer compartment and the refrigerator compartment to cool them both down to their set temperatures.
If for whatever reason there is a problem with the fan, then the freezer compartment will stay cool, because that is where the evaporator unit is located but the refrigerator compartment will get warmer because no cold air is being blown into it to cool it down.
You need to access the fan which is behind a panel on the inside at the back of the freezer compartment, (access through the door at the front) and check that it is operating OK.
Be aware that the fan will stop when the door is opened. I think that you may be able to fool the control board that the door is shut by manually operating the freezer door switch with the door open, so that you can see the fan operating. The fan should run as long as the compressor is running.
If the fan is iced over then there is a defrost problem which could be caused by a faulty defrost heater, defrost thermostat or a blocked drain from under the evap unit to the evap pan under the compartments.
If the fan is faulty, replacement are available online. Just search for RF220NCTASR/AA parts to find suppliers that suit you best.
Here’s a link to the service manual that may help.
It shows how to get into the self diagnostic mode so all the functions can be tested and also what to check if they’re not working properly.
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
