Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ordinateur portable convertible 2-en-1 de 1re génération de la gamme ThinkPad X1 de Lenovo, doté d'un écran tactile de 14" qui s'accompagne d'un stylet inclus. Sorti en 2016 avec le numéro de modèle 20FQ00****
new battery still shuts down when ac power is unplugged
laptop shows battery charge is at 100%. when I unplug the ac power the laptop immediately shuts down even with new ifixit battery. ive tried several different ways to reset it. looking for more suggestions.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi,
Just to verify that the battery is OK, create a battery report to check it status.
Compare the Design Capacity value against the Full Charge Capacity value. With a good battery they should be nearly the same.
Does it do this if you reconnect the old battery again?
Indice 1
8 commentaires:
I did a battery report. It checked out okay. The capacity values were nearly the same. But with the old battery, the computer would pop up a screen that said the battery was bad and needed to be replaced. It did the same thing to where it would shut off immediately after AC power was unplugged.
par
I'm suffering from exact same.
# upower --show-info /org/freedesktop/UPower/devices/battery_BAT0
vendor: ifixit
model: bq20z451
power supply: yes
updated: Tue Jul 23 12:32:35 2024 (0 seconds ago)
battery
present: yes
rechargeable: yes
state: fully-charged
energy: 50.1676 Wh
energy-empty: 0 Wh
energy-full: 50.1676 Wh
energy-full-design: 53.2 Wh
voltage: 5.679 V
charge-cycles: 49
percentage: 100%
temperature: 28.2 degrees C
capacity: 94.3%
technology: lithium-ion
Whenever I unplug the charger, laptop dies instantly. As the battery is "100%" full, it won't charge.
It seems, there is no option to limit charging into 80% or similar. Also, it wouldn't help as the battery won't discharge from 100%.
par
@hqjatu
Try uninstalling the Microsoft ACPI- Compliant Control Method battery driver in Device Manager and then restarting the laptop to allow Windows to reinstall it again and check if this resolves the problem.
To get to Device manager in Win10/11 press the Win key + x key (both together) and click on the Device Manager link.
When in Device Manager go to Battery → right click on the Microsoft ACPI- Compliant Control Method battery entry → Uninstall this device and follow the prompts and then restart the laptop in the normal manner.
par
Just to be crystal clear:
Running a upower --show-info /org/freedesktop/UPower/devices/battery_BAT0 as root should point to correct direction of operating systems. Hint: non-Windows
So, unfortunately I cannot try that suggestion.
par
@hqjatu
Try the suggestions in this link
par
Voir 3 commentaires en plus
Ajouter une réponse
anthony samsel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 54
Total : 2,203
