Aller au contenu principal
My lock fob has suddenly stopped working on my Ford Fiesta 2012 plate
My key fob has stopped working on my fiesta. I can use the key to manually lock and unlock the doors.
can’t change battery as it’s a sealed unit
Update (09/02/2021)
her is a picture of my fob
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Hi @joys2121 ,
Here’s a video that shows how to open your key fob to replace the battery.
The battery model used is a CR2032. It is a common battery available most everywhere e.g. supermarkets.
Note: Ensure that you insert the new battery the same way as the original. There is a +ve symbol marked on the battery so that you know which way it goes into the battery holder.
Indice 1
1 commentaire:
Thank you so much for your help changed battery easily with the help of you tube had to re program after changing the battery but google helped with that
par
Réponse la plus utile
Hi @joyspurrier, can you attach a photo of the key fob? (Click here for directions on how to add photos to your post.)
Even with the “sealed” devices you can usually get into them with a spudger (or a guitar pick, credit card, or flat head screwdriver). Once you’re in, you should be able to swap out the battery. This guide has a quick video example of using the key to open their fob.
Hope this helps!
Image iFixit
Tutoriel
Ajout d'images à une question existante
Difficulté :
Très facile
2 - 5 minutes
Image 2009-2015 Toyota Prius Pile de plip
Tutoriel
Remplacement de la pile du plip (clé-télécommande) de la Toyota Prius 2009-2015
Difficulté :
Très facile
2 minutes
Indice 1
Ajouter une réponse
joy s sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 30
Total : 726
