Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation et l'entretien de la gamme de disques durs externes USB WD Elements Desktop de Western Digital. Disponibles en configurations 3 To, 4 To, 6 To, 8 To, 10 To, 12 To et 14 To.
Is it possible to turn this device into a portable drive?
Hello all I have a question, I have a couple of these devices in different capacities (along with the WD My Book) and what I am wanting to know is if it is possible to take the drive out of the inside and put it into another enclosure and make it a portable drive where it does need a power supply?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Yes, it is possible to put this drive in another enclosure (follow this guide). Before you get an external enclosure, make sure you're getting a SATA enclosure and the enclosure matches your Hard Drive (2.5” or 3.5”).
Indice 1
3 commentaires:
But is is possible to make it portable instead of requiring a power supply? Also, how do I know if the drive inside the enclosure is a 2.5 or a 3.5 without having to open it up?
par
No, Everything requires power. It is labeled as INTERNAL USE because it requires 12V. An external drive only requires 5V that is supplied via the USB connection. Some older drives will only function with a double USB connector because they require more current than USB 2 can supply.
par
ok thanks for your help, I kind of figured as much but was just wondering. Any recommendations for a good multiple drive holders, cause what I am really trying to do is cut down on the number of items I have plugged into power receptacles.
par
Ajouter une réponse
Louis Wilson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 21
Total : 573
