Aller au contenu principal
The 6th generation of the Moto E smartphones. Model numbers XT2005-1, XT2005-3, XT2005-4, and XT2005-5.
When somebody tries to call me it goes directly to voicemail and I don
What could be wrong with my phone it's incoming calls not all of them but some of them go straight to voicemail again and they don't my phone don't ring
Répondre à cette question J'ai le même problème
Indice 3
3 commentaires
It only happens w one caller who is in my contact list!
par
On some low cost systems, your home WiFi service is used for phone calls. Unfortunately, in my experience, this part of the service is not always reliable. When I was away from my home, I had no trouble with incoming calls, and when I was at home I could place outgoing calls with no issues. But at home, with incoming calls, the call went straight to voicemail.
In the end, I changed carriers to Consumer Cellular, who doesn't use WiFi connections at home, and y system worked just fine and the price was lower than most other carriers.
par
When some people try calling going directly to voice mail?
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
I know of 2 reasons:
  1. Do Not Disturb is on. This often gets set accidentally because it's in the pull down menu when you swipe down from the top of the screen. Solution: Swipe down from the top and turn off Do Not Disturb.
  2. This can be done with individual contacts. Open the contact from your list, tap the 3 dots upper right corner, and there you can select to send straight to voicemail or deselect send straight to voicemail.
Indice 2
Hi @johnsgirls0331,
How many signal bars are showing on the screen when you think that you have missed calls etc?
If you're in a bad reception area i.e no signal bars, the phone may lose contact with the phone tower and if the phone can't be contacted the calls will go to voicemail. You shouldn’t be able to call out either if this occurs.
This can sometimes also happen when in buildings or in underground carparks etc. anything that can reduce the amount of signal being sent/received by the phone.
Indice 1
Hi @louisjorge
Check that the number hasn't been blocked in the phone's Contacts list
Indice 0
Ajouter une réponse
Rose Faulkner sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 117
Total : 20,800
