Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Lenovo Yoga C930-13IKB est un ordinateur portable 2-en-1 doté d'un écran tactile, d'un lecteur d'empreintes digitales et d'un mode tablette. L'appareil est livré avec un stylet Lenovo Active, un adaptateur secteur 65 W, une batterie Li-Polymère 4 cellules 60 Wh et un guide de démarrage rapide.
Both of my USB C ports now no longer charge laptop.
Both of the USB C ports on my laptop no longer have a solid connection when I plug in my charger. The charger used to have a “click” when I plugged it in, and now it doesn’t do that and the cable seems loose. I can’t get a steady charge from the cable on either port. I’ve tried multiple laptop USB C chargers, so it’s not the cable. Are the ports repairable?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @nachokingp ,
Both the USB-C ports are hard mounted on the systemboard, so you will need smd soldering skills and tools to replace them.
Visually inspect the ports, using a strong light and a magnifying glass to check if you can spot a problem either with the pins or the port enclosure.
If there appears to be dust or lint etc in the enclosure, that may be preventing a good electrical connection, do not use a metal pin or probe to try and extract it, use a vacuum cleaner instead to try and suck it out.
Here’s the hardware maintenance manual for the laptop. Go to p.46 to view the necessary pre-requisite steps and then the procedure to remove the systemboard as this will need to be done to replace the connectors.
If doing all this seems too daunting, contact a reputable. professional laptop repair service and ask for a quote.
Indice 3
Ajouter une réponse
Brian Remite sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 1,302
