Aller au contenu principal
Processeur quad-core Intel Core i7 à 2,0 GHz, 2,3 GHz ou 2,6 GHz (Turbo Boost jusqu'à 3,8 GHz) avec 6 Mo de cache L3 partagé.
20 questions Voir tout
external disk similar to internal one
My MBP 15” late 2013 retina display is running latest Catalina 10.15.7 OSX and has MZ-JPU512T/0A6 disk, which is 512 GB PCI-e 2.0 SSD, and I’m going to buy ssd external disk to test upgrade to new OSX Big Sur.
What kind of external disk do you suggest to buy ? What characteristics similar to internal drive?
I thought to avoid NVMe technology; I’d like to but USB 3.0 disk with SATA interface.
What do you think?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Why are afraid of NVMe drives?
You are aware the controller chip is the only difference between the different drives: SATA to Flash or PCIe/NVMe to Flash or USB to Flash
par
Ajouter un commentaire
1 Réponse
I personally like the Samsung T5 drives but that was quite a few years ago. Today I would go with the newer T7 drives.
Samsung Portable SSDs: T5 vs. T7 vs. T7 Touch
The issue you face is the interfaces your system series offers. The Thunderbolt 2 ports offer up to 20 Gbps I/O each and the USB-A ports up to 5 Gbps I/O each. The newer Thunderbolt 3 ports in the 2016 models onward offer up to 40 Gbps via USB-C connections.
Even still having a fast interface on your system still is limited by the technology of the drive. A SATA based drive won’t be able to match the SSD’s speed, so I don’t think you’ll get the same performance.
If you need something faster then you need a RAID setup using your Thunderbolt 2 port, sadly, the direction for most of the RAID systems is embracing USB-C or enterprise based connections which are just not portable.
Indice 0
Ajouter une réponse
Riccardo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 72
