No system audio device listed
The system audio device of my Mac Mini 2012 isn’t available, neither in System Preferences nor in the System Report.
I bought this Mac Mini only recently second hand, replaced the second hard drive with an SSD, and made a clean install install of OS X 10.11. I hardly used the computer before and therefore can’t say for sure if the system audio device had been working before.
Any clues what could be the cause, and how to fix it?
Audio output over DisplayPort/HDMI works. SMC and PRAM reset did not solve this issue.
Update (11/11/2021)
@danj Thanks again for your help. I had another look at the logic board but found no suspicious traces near the audio chip - at least no difference to other areas. Maybe you can see something?
I think I’ll leave it as it is now before I cause any serious damage to the Mac’s innards - unless of course you or someone else have further suggestions.
5 commentaires
Lets give the board a clean using some 90% isopropyl alcohol and a soft brush to pull away the dust & dirt. lets see how it looks then.
par Dan
@danj AIUI, cleaning the board would only help identify existing damage to the board, wouldn't it? I'm hestitant opening the case yet again and risk serious damage by ESD or broken connectors. Thanks anyway for the suggestion.
Meanwhile I spoke to the seller, who (maybe tellingly) mentioned an USB audio interface they've been using ...
par Jo H
@Jo H - If you can return it and get your money back then I would.
par Dan
@danj Bad luck for me - I bought this Mac Mini months ago and did some initial checks back then, including the Thunderbolt and Ethernet ports but not the audio device. Then I set it aside until a rainy Saturday afternoon (which we finally had in November). I can't possibly return it after several months, and besides, if the audio device remains the only broken component, it's still been a fairly good deal.
par Jo H
@Jo H - Then look at a USB DAC device there are quite a few out there!
par Dan
