Aller au contenu principal
Help for Samsung televisions with model code LN32D403.
Questions au sujet de 2 Voir tout
My Samsung television keeps glitching out
My Samsung television keeps glitching out for years now. Today, it got worse, and the glitching was followed by a “Weak or No Signal” message. Why does this keep happening? Solutions are welcome.
My Samsung TV model is LN32D403T-MX5HAUSC-1009.0.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
What is the source of the TV signal, a TV antenna or a cable box etc?
Try enabling the digital noise filter setting in the TV and check if that improves the signal and resolves the problem.
If still no good and if the TV is connected to an outside TV antenna, check that the antenna is pointing directly towards the TV transmission tower so as to maximize the signal strength. Compare it to other antennas in your neighbourhood to get the direction.
If the TV is connected to an indoor antenna, you may need to boost the signal with an antenna amplifier (supplier example only)
Indice 3
Ajouter une réponse
Gabi Salinas sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 77
Total : 692
