Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Processeur 1.4GHz ou 1.6GHz, SSD de 64 Go or 128 Go.
Strange audio/mic problem on MacBook Air
I haven’t been able to find a solution to this for over a year. When I’m on Zoom or FaceTime using internal speakers and mic, I can hear other people but nobody can hear me. Instead of hearing my voice they can hear sounds if I tap on the keys or move the mouse. When I use ear buds, they can hear me but NOT when I use wired earphones. This was fine for a while but now my earbuds are dying and I need to have other alternatives for video calls for work. Please help!?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Sounds like the headphone jack has messed up! What a lot of people forget there is a set of switches within the jack to redirect the audio signal to the speaker output from the headphone. In your case one of the switch element has shorted across the microphone line or the connection between the I/O board to the main logic board has a problem.
Here’s the guide to get it out MacBook Air 11" Late 2010 I/O Board Replacement and you should replace both of these parts
That should fix things.
Image Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.
Produit
MacBook Air 11" (Late 2010) I/O Board
$29.99
Image Replace an I/O board cable compatible with the Late 2010 to Mid 2011 MacBook Air 11" laptop. Fix the connection between the I/O board and the logic board.
Produit
MacBook Air 11" (Late 2010-Mid 2011) I/O Board Cable
Indice 0
Ajouter une réponse
B K sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 263
