Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en 2017, l'ASUS ROG Strix GL503VD est un ordinateur portable de jeu haute performance.
Battery is charged but laptop stops on unplug
Hello,
I have an ASUS GL503VD laptop and I have an issue with the battery.
The BIOS shows that my battery is 91% charged but when I unplug my laptop, it just stops…
The percentage of the battery is always 91% and does not change at all.
What I tried :
  • Factory reset
  • BIOS reset/update
  • Driver reset/update
  • Open the laptop to unplug/plug the battery connector
Can someone help me to solve this please ?
Thank you in advance.
Répondre à cette question J'ai le même problème
Indice 2
8 commentaires
same issue however i replaced the old battery for a new one but still the same issue
par
What does your bios do if you are looking at it when you unplug the cord?
par
a new battery did not solve it for me
par
@caperry8 it just shutdown instantly
par
@Brian Beckford I don't think that will solve mine either ...
par
Voir 3 commentaires en plus
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@rtxx
Which driver did you reset?
Did you try uninstalling the Microsoft ACPI-Compliant Control Method Battery from Device Manager > Battery and then after it has uninstalled restart the laptop and let Windows "find" and install it again? Also check if it has the latest drivers installed. Right click on the entry and click on Update drivers and follow the prompts.
Create a battery report to check the status of the battery. When you have the report, compare the Design Capacity value versus the Full Charge Capacity value to determine it status. With a good battery they should nearly be the same.
Indice 1
6 commentaires:
PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
2021-12-20 49 096 mWh 64 448 mWh
2021-12-21 49 096 mWh 64 448 mWh
2021-12-22 49 096 mWh 64 448 mWh
2021-12-23 49 096 mWh 64 448 mWh
2021-12-24 49 096 mWh 64 448 mWh
2021-12-25 49 096 mWh 64 448 mWh
2021-12-26 - -
par
And yes I've already uninstalled Microsoft ACPI-Compliant Control Method Battery and updated it
par
@rtxx
As the laptop stays on when the charger is connected, it appears as though it is a hardware problem on the motherboard, i.e. no power into or out of the battery.
What is the model number of the motherboard? It may be necessary to find the schematics for the motherboard and usually they are easier to find when you know the board number than just the laptop name and model number.
par
The model number is dabklmb28a0
par
@rtxx
Unfortunately I can't find any schematics only boardview links, which doesn't help as they only show the location of components on the motherboard.
Found this link which didn't solve the problem but maybe will give you some ideas of where to look.
It appears that you are not the only one with this problem.
par
Afficher 1 commentaire en plus
You should consider replacing the battery…
How old is the computer?
Indice 0
1 commentaire:
The laptop is 3 years old.
I'll buy a new battery this week to try it
par
Ajouter une réponse
Rtxx sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 35
Total : 1,884
