Aller au contenu principal
A wireless speaker released in 2012
3 questions Voir tout
Bowers Wilkins A7 connection issue
I have a Bowers Wilkins A7 wireless speaker.
It can’t be connected successfully now either with WIFI, wire, USB or AUX. The red light just keep flashing indicating the connection issue.
Resetting the device didn’t work either.
It is an old device with little information on how to fix this.
Is there any way to check the root cause of the issue?
Répondre à cette question J'ai le même problème
Indice 1
8 commentaires
Hi,
Have you tried resetting the device, you didn't say?
par
Yes, tried that.
After resetting, the red light just flashed.
par
Seems can't do the firmware update.
Connected with USB not work.
par
@Shawn Chen
Did you try using the Control app?
par
@jayeff
Yes, tried to but can't connect either.
The device can't connect in any way.
I have tried to reset and connect several times with no success.
par
Voir 3 commentaires en plus
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@Shawn Chen
The only thing I suggest now is to open the speaker and check for any obvious problems on the systemboard.
Here's a link that may be of some help. There is also a wiring diagram in the answer as well. ;-)
Bowers and Wilkins A7 How to disassembly the unit
Indice 2
1 commentaire:
Thanks a lot @jayeff .
Will follow this and check accordingly.
par
@shawnchen
I think I have the same issue. And in my case I am sure it is the WiFi module, because I was able to swap it with a working WiFi module and then the A7 worked perfect.
So I am looking for a way to repair the WiFi module.
Here's my post.
Did you find a solution in the meantime?
Indice 0
Ajouter une réponse
Shawn Chen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 22
Total : 1,403
