Why Your Hard Drive Gets Slow
HDDs and SSDs are commonly used in your daily life to store films, games, and other files rather than with a flash drive or a DVD. However, sometimes a hard drive may become slow to read and write, and for no obvious reasons. To find out the reasons and solve the slow hard drive issue better, you should give you a head start on understanding what causes slow performance.
- 1. Torrents and P2P software
- 2. Insufficient power or USB ports
- 3. Not enough free hard drive space
- 4. Logic errors and bad sectors
- 5. Damaged disk
- 6. Hardware failure...
Now that you have known the reason why the hard drive takes a long time to read, you can follow the fixes to solve your problem and speed up your hard drive easily.
Fix 1. Upgrade the Hard Drive
Fix 2. Uninstall Unwanted Programs
Fix 3. Check the Speed
Fix 4. Switch the SATA
Fix 5. Clean Up Junk Files
A voté
Annuler
Indice
-1
question does not give enough info to diagnose.
how are you determining speed?
are you saying wifi speed is normal but Ether speed is not?
Internet speed is upload/download not read/write - what are you talking about?
par bill
