Hi @donley,
What is the problem with the washer?
In diagnostic mode a blinking sensing light only, indicates a No fault condition See F0 E0 code in 2nd image below and description of how the lights are interpreted in the 1st image below
F0 = sensing light on (F) + no other lights (0)
E0 = sensing light off (E) + no other lights (0)
So the blink pattern for an F0 E0 code would be that only the sensing light should be on for 0.5 seconds in every 2.5 seconds or on twice in 5 seconds to make it easier to tell
Maybe check that the other lights - wash, rinse, spin and done, all work when performing the UI Test mode - see p.4 & 5 in the tech sheet, just in case one of these is faulty.
Here are some images from the tech sheet for your model, showing the error codes and how they’re interpreted.
(click on images to enlarge)
A voté
Annuler
Indice
6
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
