Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La montre connectée cinquième génération d'Apple, avec connectivité cellulaire en option, commercialisée le 20 septembre 2019.
Force touch sensor still not working after replacement
I replaced my Apple Watch series 5 44mm lte force touch gasket as mine was damaged when I was replacing the screen (I need to reset it using the force touch as it is password locked) and when I replaced it and tried to do it, it still did the same thing. Any ideas on what might be wrong??
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
So it turns out i needed too hold the power button (with it charging) then hold the crown.
Indice 0
Do you know if it is running WatchOS 7 or newer? Apple removed the force touch sensor’s function in WatchOS 7 and replaced most of its functions with a long tap
Indice 0
2 commentaires:
Im honestly not sure, ive tried long pressing and it did nothing so i presume its not.
par
Same problem for me after replacing the screen and the force touch sensor. Not sure I did the adhesives correctly on the repair. The video shows using an adhesive instead of the actual parts that ship with the repair. Is there a way to show the actual repair you need to do here?
par
Ajouter une réponse
John Dragonette sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 31
Total : 635
