Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Processeur 1.4GHz ou 1.6GHz, SSD de 64 Go or 128 Go.
Why do my function keys not correspond to the legend?
I have a 2010 MacBook Air that works great, except that the keyboard backlight does not work and the function keys are offset by one, for example if I press the pause key it skips back, which is what the button one key to the left should do. Please Help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
I managed to fix it by installing a program called karabiner elements which reset everything.
Indice 0
Apple redid the keys assignments between your series and the newer models
Go into your keyboard settings within Preferences see if the Use F1, F2, etc… option is checked off? I would check on Show keyboard and emoji viewers so you can then have that visible to see if the keys are working correctly.
Let us know what you discover.
Indice 0
2 commentaires:
The board works and all the keys are received correctly. How do I remap them or fix this problem? I am running high sierra.
par
@nhelle - Lets see if resetting the SMC and NVRAM fixes things.
How to reset the SMC of your Mac
Reset NVRAM or PRAM on your Mac
par
Ajouter une réponse
Nathaniel Hellewell sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 292
