Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Multifunction wireless inkjet printer (scan/copy/fax), released 2013 from Canon. Identified by the "MX922" on the front of the machine, above and to the right of the "Canon" logo.
Ghosting only on blacks, colors are okay
My Canon Pixma MX922 has a print ghosting problem only on the two black inks. Colors look good. Canon recommends cleaning the encoder/timing strip with IPA. I have done this multiple times with no performance change. Any ideas what the cause could be? Would a bad print head do this? Do I need to disassemble the printer to access and clean the encoder/timing read sensor?
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Hi @damon10 ,
Just curious if it does this when printing or scanning using the printer control panel or from a computer or both?
par
Ajouter un commentaire
1 Réponse
Solution retenue
@damon10 yes, a partially clogged print head could be the issue. Check on here how to clean it
Indice 1
1 commentaire:
I did throughly clean the print head. It did not fix the issue. I can try that again. It just wastes ink that has flowed from the ink cartridges into the reservoir of the print head. A few other people posted this same issue on Canon’s support sight. Canon’s response was clean the timing strip, which didn’t fit it for us.
par
Ajouter une réponse
DTG sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 34
Total : 1,077
