Home screen wont load
Home screen wont load just flashes and goes to the most recent app
Hi,
Try starting in safe mode and check if it works OK. if it does it may be a downloaded app that is the problem. The trick is to find out which one is the cause.
Also try wiping the cache partition in case it is corrupted temp data that is the problem
Alright this is a pretty easy fix!
Here a few things you can try. I have a feeling that the launcher your phone uses either may not be setup correctly in settings or is corrupt. Don’t worry tho here are a few tricks!
Hope these methords work. If not you will need todo a hard reset which can be found on hardreset.info
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 8
Total : 204
