Hi,
Since we don’t know what “I did all way to fix (in term of technology) it but it didnt work…..” entails, did you check if the microphone is being detected when plugged in or are you using the inbuilt microphone?
I’m not sure with your model whether it has an inbuilt microphone up near the webcam or whether you have to plug one into the combo jack on the laptop
Go to Control panel > Sounds > Recording. To get to Control panel in Win 10, type control panel in the Windows search box on the desktop and click on the Control Panel app that appears.
When in Sound - Recording if it shows that the microphone is detected, click on the entry - Properties and check in Device Usage that it shows use this device (enabled)
If it’s not being detected, check that the Sound Controller in Device Manager is working OK. To get to Device Manager in Win 10, press the Win key + x key (both together) and click on the Device Manager link.
When in Device Manager scroll down and click on the > symbol to the left of the Sound, video and Game controllers category to expand the list and the right click on the Realtek HD audio entry - Properties - General tab - Device status and check if it shows “This device is working properly”.
If it does and the microphone is not being detected (or even if it is, but there is no audio connection from the mic) if you have to plug in the microphone, you may have a faulty I/O board (supplier example only), or the board may have a loose cable connection.
Here’s the owner manual for the laptop taken from this support webpage. Go to p.52 to view the necessary pre-requisite steps and then the procedure to remove/replace the board.
There are other suppliers online that may suit you better. Just search for 2WMGK 02WMGK LS-DO71P to get results
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
