Aller au contenu principal
System: AMD A4-6300 3.70GHz Dual-Core | AMD A58 Chipset | 8GB DDR3 | 1TB HDD | Genuine Windows 10 Home 64-bit Graphics: AMD Radeon HD 8370D Video | 24X DVD±RW Dual-Layer Drive | Audio: 8 Channel | Gigabit LAN | Card Reader | Keyboard and Mouse Expansion Bays/Slots Total(Free): 2(1) Ext. 5.25" | 1(1) Ext. 3.5" | 3(2) Int. 3.5" | 1(1) PCI | 1(1) PCI-E x1 | 1(1) PCI-E x16 | 2(1) DIMM 240P Connectivity: 6x USB 2.0 | 1x RJ-45 Network Ethernet 10/100/1000 | Audio | 1x VGA | 1x HDMI Chassis: Stylish Gaming Chassis w/350 Watt Power Supply
Questions au sujet de 3 Voir tout
I cant change the RAM usage to 5.0 to 7.2 and I have W10
It can go up to 7.2 but it is locked at 5.0
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @nytryder26 ,
How much memory is listed when you go to System Configuration > Boot tab > select OS installed if more than 1 installed > Advanced > memory?
To get to System Configuration, press and hold the Win key then press r key, then type msconfig in the box and click OK
Indice 3
7 commentaires:
7.2 is the max but it can only use 5
par
@nytryder26
Did you try to change it there?
How much ram is installed? Was amount does it show in BIOS?
par
@jayeff It has an 8GB RAM the total is 7.2GB but the limit is 5GB.
par
@nytryder26
Is there any memory mapping set in BIOS?
par
@jayeff I don't think so
par
Voir 2 commentaires en plus
Ajouter une réponse
NR26 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 107
