My screen is peeling off.
my screen is loose on one corner so I can see the glow on the inside.
Nathaniel Mello looks like your screen is separating. You can try and see if you can reseat it. If you can't you may have to replace it. Use something like this video to work on the display.
Hi Nathaniel,
Is the display still fully functional?
If it is, you most likely don't need to replace it like oldturkey said. Instead, you can follow this tutorial: Samsung Galaxy A10 Screen Replacement - iFixit Repair Guide to carefully remove the display, clean off the old adhesive and glue it back down.
If you don't feel comfortable fully opening up your phone, you may be able to slide a thin, flexible plastic card in between the display and the frame to separate the screen from the rest of the phone. You may need to use something like Isopropyl alcohol to help slice through the adhesive. You will also need to be very careful of the display flex cable near the bottom of the phone. After you've separated the display, ideally you would use something like E8000 or B7000 to adhere it back in place. Failing that, you can use strips of double-sided tape all around the back edge of your display.
I hope this helps :)
Let me know if you have any other questions
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 1,526
3 commentaires
Have you replaced your screen recently, or had your device opened at any point?
par Jacob Mehnert
@jmehnert not that I know of, it is a hand-me-down tho so i cant say
par Nathaniel Mello
I currently have the same phone screen issue I've had my Phone for a with but I had gotten it new & I haven't had the screen replaced
par Jeffrey Brennan
