Headphone spot not working
When i insert headset its doe not work and shoes that headsets are inserted
Hi,
It could be a faulty headphone jack or worst case a problem on the systemboard.
For a DIY repair, the easiest option is to replace the charge port board in the phone as the headphone jack is mounted on the board and check if it then works OK. The supplier linked was only to show you what the board looked like and how much it may cost. There are other suppliers online that may suit you better. Just search for Samsung Galaxy A10s charge port board to get results.
Here's a video that may help you to remove/replace the board. I realize that it shows how to fix the charge port and not replace the headphone jack, but it does show how to open the phone and to access the board and remove it.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 19
Total : 426
2 commentaires
Hi,
When playing music etc on the phone, does the sound from the phone's speaker stop when you plug in the headphones?
Have you tried a different set of known working headphones to see if the sound can be heard using them?
par jayeff
𝚈𝚎𝚜 , 𝚝𝚑𝚎 𝚖𝚞𝚜𝚒𝚌 𝚜𝚝𝚘𝚙𝚙𝚎𝚍 𝚠𝚑𝚎𝚗 𝚒 𝚒𝚗𝚜𝚎𝚛𝚝 𝚝𝚑𝚎 𝚜𝚎𝚝.
𝙸 𝚍𝚒𝚍 𝚝𝚛𝚢 𝚏𝚎𝚠 𝚍𝚒𝚏𝚏𝚎𝚛𝚎𝚗𝚝 𝚠𝚘𝚛𝚔𝚒𝚗𝚐 𝚜𝚎𝚝 𝚋𝚞𝚝 𝚜𝚝𝚒𝚕𝚕 𝚝𝚑𝚎𝚛𝚎 𝚒𝚜 𝚗𝚘 𝚜𝚘𝚞𝚗𝚍
par Meisie Sefatsane
