Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Informations sur la réparation, le démontage et le diagnostic de la Steam Deck avec écran LCD, une console de jeux portable fabriquée par Valve, sortie le 25 février 2022. Elle porte le numéro de modèle 1010.
Broken jack connector after falling
hello, I am looking for the reference of the jack connector to replace it, can you help me?
FYI all pin of the connector broke after a 20cm fall with the jack plugged in
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
I found the reference for the jack connector only if this can help someone else :
brand : WNRE
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi there,
as you might have noticed we just made a bunch of Steam Deck parts available in our stores.
We definitely have a guide for this problem (but not that specific spare part, yet). So make sure to check back for more parts that might join the current selection (though I can’t promise anything since I don’t know). Hopefully, you can manage until this part is available.
Meanwhile:
As I understand it the actual headphone port on that audio board is broken, which means you might try and fix it by soldering as long as the solder joints on the board weren’t damaged.
If it’s "just" the headphone jack itself (TRRS plug from your headphone) that got stuck in the port you might be able to get it out using this nifty tool.
Cheers and game on
Image GripStick is a tool designed to easily remove broken 3.5mm headphone plugs from jacks
Produit
GripStick Headphone Plug Extraction Tool
$24.99
Indice 1
Ajouter une réponse
[deleted] sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 27
Total : 1,102
